نجد جميع انواع الحلي مصنوعة من الزمرد الاخضر خاصة لجمالها وبروزها و تميزها من ناحية اللون والشفافية ..و كان معظم الشخصيات الاوروبية والامريكية المشهورة قديما تختاره في تزيين حليها وتيجانها وتحديدا في خواتم الرجال والنساء. هذه صور لتشكيلة من بعض خواتم الزمرد الجميلة الناطقة بتميزها الفريد :![]()
Beryl may be the colorless mineral which makes up the majority of the composition associated with emeralds. It requires quite a few chromium or even vanadium to give a good emerald ring its beautiful green color. You will see that many emeralds are given oil in order to to seal cracks and increase the clarity and the regarding its colour. It is really an acceptable as well as necessary practice, because the oil fills small natural cracks within emerald rings helping keep it through cracking. Never soak a good emerald ring, or even place it within an ultrasonic cleaning device. Soaking it is going to remove the essential oil, making the rock look dull or even matte, but it will surely be simpler to crack the rock. Just the heurt alone in one of these machines may split the stone anyhow, so stay away from all those, even though you come with an emerald and gemstone engagement ring. The actual diamonds in that kind of ring must be washed some other method, like with a jewellery polishing towel. emerald engagement rings are extremely rare that should you have a superior high quality, flawless emerald green, it will likely be more useful than a top quality, flawless gemstone. Emeralds are thought flawless when they contain only blemishes that require a magnifier device to find out. That is the fault almost all emeralds contain blemishes. A high quality emerald is only one that is perfect and has a beautiful, dark eco-friendly color into it. Since almost all emeralds contain flaws as well as small cracks, actually stones treated with essential oil can crack or crack if they are handled roughly. Always eliminate emerald engagement bands, and all emerald green rings if you choose household chores, play sports activities, garden, or even anything where the engagement ring could take a tough hit.
